SOLVED Could not create WMI locator class (80040154)
Sabian Cullum
I have looked at everything on google on this topic to no avail. Please if anyone can help i will be very grateful!
LOGGING: Finalize process ID set to 944 TSBootShell 568 (0x0238)
==============================[ TSBootShell.exe ]============================== TSBootShell 568 (0x0238)
Succeeded loading resource DLL 'X:\sms\bin\x64\1033\TSRES.DLL' TSBootShell 568 (0x0238)
Waiting for PNP initialization... TSBootShell 560 (0x0230)
RAM Disk Boot Path: NET(0)\BOOT\X64\IMAGES\BOOT.NHS00005.WIM TSBootShell 560 (0x0230)
Booted from network (PXE) TSBootShell 560 (0x0230)
Network(PXE) path: X:\sms\data\ TSBootShell 560 (0x0230)
Found config path X:\sms\data\ TSBootShell 560 (0x0230)
Booting from removable media, not restoring bootloaders on hard drive TSBootShell 560 (0x0230)
X:\sms\data\WinPE does not exist. TSBootShell 560 (0x0230)
X:\_SmsTsWinPE\WinPE does not exist. TSBootShell 560 (0x0230)
Executing command line: wpeinit.exe -winpe TSBootShell 560 (0x0230)
The command completed successfully. TSBootShell 560 (0x0230)
Setting offline Windows drive and OS root directory to Task Sequence environment. TSBootShell 560 (0x0230)
Processing volume C:\ TSBootShell 560 (0x0230)
spLocator.createInstance( ((bUseAdminLocator == true) ? CLSID_WbemAdministrativeLocator : CLSID_WbemLocator ) ), HRESULT=80040154 (X:\bt\1204713\repo\src\Framework\Core\CCMCore\WmiNamespace.cpp,264) TSBootShell 560 (0x0230)
Could not create WMI locator class (80040154) TSBootShell 560 (0x0230)
spNamespace.Open(pszNameSpace), HRESULT=80040154 (X:\bt\1204713\repo\src\Framework\TSCore\diskutils.cpp,1393) TSBootShell 560 (0x0230)
Failed to connect to WMI namespace \\.\ROOT\CIMV2 TSBootShell 560 (0x0230)
Volume C:\ is a USB device. TSBootShell 560 (0x0230)
Processing volume X:\ TSBootShell 560 (0x0230)
Volume X:\ is not a local hard drive. TSBootShell 560 (0x0230)
_OSDDetectedWinDrive='', _OSDDetectedWinDir='' TSBootShell 560 (0x0230)
Starting DNS client service. TSBootShell 560 (0x0230)
Executing command line: X:\sms\bin\x64\TsmBootstrap.exe /env:WinPE /configpath:X:\sms\data\ TSBootShell 560 (0x0230)
Execution complete. TSBootShell 560 (0x0230)
hMap != 0, HRESULT=80070002 (X:\bt\1204713\repo\src\Framework\TSCore\environmentscope.cpp,495) TSBootShell 560 (0x0230)
m_pGlobalScope->open(), HRESULT=80070002 (X:\bt\1204713\repo\src\Framework\TSCore\environmentlib.cpp,335) TSBootShell 560 (0x0230)
this->open(), HRESULT=80070002 (X:\bt\1204713\repo\src\Framework\TSCore\environmentlib.cpp,561) TSBootShell 560 (0x0230)
::RegOpenKeyExW (HKEY_LOCAL_MACHINE, sKey.c_str(), 0, KEY_READ, &hSubKey), HRESULT=80070002 (X:\bt\1204713\repo\src\Framework\TSCore\utils.cpp,905) TSBootShell 560 (0x0230)
RegOpenKeyExW is unsuccessful for Software\Microsoft\SMS\Task Sequence TSBootShell 560 (0x0230)
GetTsRegValue() is unsuccessful. 0x80070002. TSBootShell 560 (0x0230)
End program: TSBootShell 560 (0x0230)
Finalizing logging from process 944 TSBootShell 560 (0x0230)
Finalizing logs to root of first available drive TSBootShell 560 (0x0230)
Successfully finalized logs to C:\SMSTSLog TSBootShell 560 (0x0230)
Cleaning up task sequencing logging configuration. TSBootShell 560 (0x0230)
TS::Environment::SharedEnvironment.isInitialized() == true, HRESULT=80004005 (X:\bt\1204713\repo\src\Framework\TSCore\tslogging.cpp,694) TSBootShell 560 (0x0230)
TS environment is not initialized TSBootShell 560 (0x0230)
I see a few things on this log that raise a flag:
spNamespace.Open(pszNameSpace), HRESULT=80040154 - I guess this is what your post is about?
and...
It will help us if you provide more details on the issue.
I know this is not a current post. But I have quite exactly same problem and wonder how @Sabian Cullum maybe fixed it.
Especially i note in my and his log the "Volume C:\ is a USB device." here , it looks like it cannot find the C: disk. Or am i wrong here ?
Is it just a disk controller driver we need ?
LOGGING: Finalize process ID set to 1236 TSBootShell 02-09-2024 13:16:15 1240 (0x04D8)
==============================[ TSBootShell.exe ]============================== TSBootShell 02-09-2024 13:16:15 1240 (0x04D8)
Succeeded loading resource DLL 'X:\sms\bin\x64\1033\TSRES.DLL' TSBootShell 02-09-2024 13:16:15 1240 (0x04D8)
Debug shell is enabled TSBootShell 02-09-2024 13:16:15 1240 (0x04D8)
Waiting for PNP initialization... TSBootShell 02-09-2024 13:16:15 1256 (0x04E8)
RAM Disk Boot Path: NET(0)\DKO00178.WIM TSBootShell 02-09-2024 13:16:15 1256 (0x04E8)
Booted from network (PXE) TSBootShell 02-09-2024 13:16:15 1256 (0x04E8)
Network(PXE) path: X:\sms\data\ TSBootShell 02-09-2024 13:16:15 1256 (0x04E8)
Found config path X:\sms\data\ TSBootShell 02-09-2024 13:16:15 1256 (0x04E8)
Booting from removable media, not restoring bootloaders on hard drive TSBootShell 02-09-2024 13:16:15 1256 (0x04E8)
X:\sms\data\WinPE does not exist. TSBootShell 02-09-2024 13:16:15 1256 (0x04E8)
X:\_SmsTsWinPE\WinPE does not exist. TSBootShell 02-09-2024 13:16:15 1256 (0x04E8)
Executing command line: wpeinit.exe -winpe TSBootShell 02-09-2024 13:16:15 1256 (0x04E8)
Executing command line: X:\Windows\system32\cmd.exe /k TSBootShell 02-09-2024 13:16:15 1240 (0x04D8)
The command completed successfully. TSBootShell 02-09-2024 13:16:15 1240 (0x04D8)
Successfully launched command shell. TSBootShell 02-09-2024 13:16:15 1240 (0x04D8)
The command completed successfully. TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
Setting offline Windows drive and OS root directory to Task Sequence environment. TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
Processing volume C:\ TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
spLocator.createInstance( ((bUseAdminLocator == true) ? CLSID_WbemAdministrativeLocator : CLSID_WbemLocator ) ), HRESULT=80040154 (K:\dbs\sh\cmgm\1026_005344\cmd\l\src\Framework\Core\CCMCore\WmiNamespace.cpp,264) TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
Could not create WMI locator class (80040154) TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
spNamespace.Open(pszNameSpace), HRESULT=80040154 (K:\dbs\sh\cmgm\1026_005344\cmd\1c\src\Framework\TSCore\diskutils.cpp,1397) TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
Failed to connect to WMI namespace \\.\ROOT\CIMV2 TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
Volume C:\ is a USB device. TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
Processing volume D:\ TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
Volume D:\ is a USB device. TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
Processing volume E:\ TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
Volume E:\ is not a local hard drive. TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
Processing volume X:\ TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
Volume X:\ is not a local hard drive. TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
_OSDDetectedWinDrive='', _OSDDetectedWinDir='' TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
Starting DNS client service. TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
Executing command line: X:\sms\bin\x64\TsmBootstrap.exe /env:WinPE /configpath:X:\sms\data\ TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
Execution complete. TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
hMap != 0, HRESULT=80070002 (K:\dbs\sh\cmgm\1026_005344\cmd\1c\src\Framework\TSCore\environmentscope.cpp,495) TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
m_pGlobalScope->open(), HRESULT=80070002 (K:\dbs\sh\cmgm\1026_005344\cmd\1c\src\Framework\TSCore\environmentlib.cpp,335) TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
this->open(), HRESULT=80070002 (K:\dbs\sh\cmgm\1026_005344\cmd\1c\src\Framework\TSCore\environmentlib.cpp,561) TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
::RegOpenKeyExW (HKEY_LOCAL_MACHINE, sKey.c_str(), 0, KEY_READ, &hSubKey), HRESULT=80070002 (K:\dbs\sh\cmgm\1026_005344\cmd\1c\src\Framework\TSCore\utils.cpp,689) TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
RegOpenKeyExW is unsuccessful for Software\Microsoft\SMS\Task Sequence TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
GetTsRegValue() is unsuccessful. 0x80070002. TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
End program: TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
Finalizing logging from process 1236 TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
Finalizing logs to root of first available drive TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
LOGGING: Setting log directory to "D:\SMSTSLog". TSBootShell 02-09-2024 13:16:26 1256 (0x04E8)
To reply to myself.
This fixed it. Uninstall ADK, reboot, actually downgrade ADK and reboot again. Then update boot image. Then it could boot.
dharibe
