SOLVED Component Not Installed by Site Component Manager
  • Thread starter Thread starter prytkov
  • Replies Replies 16
  • Views Views 22K
prytkov
Hello everyone!
I have three servers (1.sccm , 2.sql , 3wsus)
On sccm have critical error, but dont uderstand what's wrong
Thank you for your help and support
Some of the errors disappeared overnight, but why they disappeared remains a mystery.
I'm sorry, but there are still questions about other componentsСнимок-03.PNG
Hello Garth!
Ofcourse i review the component status messages, but dont understand whats wrong. The description of the problems does not give an understanding of the essence of the problem.
Now i'll try to turn firewall off on all servers, and all icons of Site Status turn to "OK"
However in tab "Component Status" i have received several warnings and several critical errors
Could you tell me where to start to find the error
Best regards
Can you tell us what errors you see for each component?.
Ill try to open messages from SMS_EXECUTIVE
Site Component Manager did not copy file "C:\Program Files\Microsoft Configuration Manager\bin\x64\system32\smsperf.dll" to "\\SRV-WSUS-01.SCCM.CORP.AERO\ADMIN$\system32\smsperf.dll", because the source file is not a newer version than the destination file.
Site Component Manager did not copy file "C:\Program Files\Microsoft Configuration Manager\bin\x64\system32\perf_msg.dll" to "\\SRV-WSUS-01.SCCM.CORP.AERO\ADMIN$\system32\perf_msg.dll", because the source file is not a newer version than the destination file.
Site Component Manager did not copy file "C:\Program Files\Microsoft Configuration Manager\bin\x64\syswow64\smsperf.dll" to "\\SRV-WSUS-01.SCCM.CORP.AERO\ADMIN$\syswow64\smsperf.dll", because the source file is not a newer version than the destination file.
Site Component Manager did not copy file "C:\Program Files\Microsoft Configuration Manager\bin\x64\syswow64\perf_msg.dll" to "\\SRV-WSUS-01.SCCM.CORP.AERO\ADMIN$\syswow64\perf_msg.dll", because the source file is not a newer version than the destination file.
Site Component Manager did not copy file "C:\Program Files\Microsoft Configuration Manager\bin\x64\system32\smsmsgs\srvmsgs.dll" to "\\SRV-WSUS-01.SCCM.CORP.AERO\ADMIN$\system32\smsmsgs\srvmsgs.dll", because the source file is not a newer version than the destination file.
Site Component Manager did not copy file "C:\Program Files\Microsoft Configuration Manager\bin\x64\system32\smsmsgs\climsgs.dll" to "\\SRV-WSUS-01.SCCM.CORP.AERO\ADMIN$\system32\smsmsgs\climsgs.dll", because the source file is not a newer version than the destination file.
Site Component Manager did not copy file "C:\Program Files\Microsoft Configuration Manager\bin\x64\system32\smsmsgs\provmsgs.dll" to "\\SRV-WSUS-01.SCCM.CORP.AERO\ADMIN$\system32\smsmsgs\provmsgs.dll", because the source file is not a newer version than the destination file.
Site Component Manager could not start the SMS_SERVER_BOOTSTRAP_SRV-INST-01 service on site system "\\SRV-WSUS-01.SCCM.CORP.AERO" to install component SMS_EXECUTIVE with the service logging on as account "". The operating system reported error 997: Overlapped I/O operation is in progress.
Possible cause: Site Component Manager does not have sufficient access rights to administer the site system.
Solution: Verify that the Site System Installation accounts are properly configured to allow the site to administer the site system.
Site Component Manager failed to install this component on this site system.
Solution: Review the previous status messages to determine the exact reason for the failure. Site Component Manager will automatically retry the installation in 60 minutes. To force Site Component Manager to immediately retry the installation, stop and restart Site Component Manager using the Configuration Manager Service Manager.
Thanks all for the help, it seems that the firewall did not work properly, I will look for which ports and on which server to open
with respect
I dont understand how it's works.
My first action turn off firewall on all servers (1.sccm 2. sql 3.wsus)
then, two days later, I sequentially turned on the firewall on one server of the queue, starting from the first and ending with the last. I expected to see service crashes , but I didn 't see any errors in the site status or in the component status.
as a result, the errors that were previously gone
Dear Prajwal Desai and Garth, please tell me which way to look in my situation. the sccm server and the sql server does not have access to the Internet, and the wsus server gets access to the Internet through a proxy. Synchronization software updates goes without errors, but it does not work to download updates, I encounter error 12007. An error occurred while downloading the software update
if you are using a proxy then it is likely blocking it. You will need to talk to your network team about that. to help prove that it is them remove ConfigMgr from the picture and show that downloading the SU with Chrome using the proxy account is failing. This blog gives the basic steps. https://www.recastsoftware.com/reso...-software-update-outside-of-the-sccm-console/
Garth thanks for the answer! Now I understand that the proxy blocks the downloading of updates, since the downloading occurs on the SCCM machine (which does not have Internet access).
Please tell me whether it is theoretically possible to work according to the following scheme:
1. SCCM server no internet
- components installed on the server
Component server
Distribution point
Management point
Service connection point
Site server
Site system
SMS Provider
2. SQL Server no internet
Component server
Site database server
Site system
3. WSUS server has Internet via proxy and SUP is installed
Component server
Distribution point
Management point
Site system
Software update point
Is it possible to download and install updates using the scheme described above, i.e. Internet access only through the WSUS server?
Component server
Distribution point
Management point
Site server
Site system
SMS Provider
Component server
Site system
Component server
Distribution point
Management point
Site system
Yes you can do that, Install the ConfigMgr console on WSUS and manually download (e.g. use the wizard) the SU to a "share" ConfigMgr will do the rest.
This config work for me (problem solved)
- components installed on the server:
Component server
Site server
Site system
SMS Provider
Component server
Site system
Component server
Distribution point
Management point
Site system
Software update point + SCCM Console
Thanks for help
mattjimf
