SOLVED Client Push is not working - SCCM Current Branch
Kevinlw
We currently have an SCCM 2012 environment and I am in the process of turning up a new one with the current branch. We have a couple of physical locations, but I am doing a single site installation.
the issue I am running into is trying to manually push the client to a test server I created. I get absolutely nothing on the test server. Nothing int he CCMSetup logs. It does not even execute the install.
I have the SCCM service account for the Client Push Properties set and verified that it does have admin rights to the machine.
I am attaching the SMSProv log file. Had to rename it as a txt file to upload it.
I understand that you are manually trying to install the SCCM client agent. Can you tell me the command line that is used to install the client agent. Is the FSP role installed ?.
No, i am not installing form the command line. i am trying to push to the machine from the console. The FSP role was not assigned. I only have two servers up right now. The site server and the SQL server.
Well, like an idiot I did not check the CCM.log first. Looked everywhere else. It turned out to be the computer account for the sccm server. It did not have access. So in the future I'll know that is there is nothing showing up on the client, check both service account and the server's computer account. Thanks for your help.
Bpalmer
