SOLVED Client Push installation is not working.
  • Thread starter Thread starter Biswajit
  • Replies Replies 7
  • Views Views 8K
Biswajit
Client push installation is not working for installing client in win7 machine, i followed all given step by step installation. :confused:did i have to copy client installation file anywhere in win7 or it will pick automatically. its not showing in task manager process.
Regards
Biswajit
CCMclient is not getting install in client machine, in task manager only ccmsetup.exe*32 is showing. ccmExec.exe process is not running because of that client is not getting installed. Could please suggest me where is the issue.
Regards
Biswajit
I have already configured the boundary related settings. then also verified, all the settings are fine as per the given step.
Find the attached task manager screen shot of client. ccmsetup32.exe is running but ccmExec.exe process is not running
I have enabled HTTP on DP instead of HTTPS, & ccmclient got installed in Win7 machine :)but its throwing some error in log files, Also not getting installed in servers. plz find the attached logs.
failed to get dp locations as expected version from mp'server'0x87d00215
Thanks Prajwal,
Issue got fixed, I reconfigured boundaries to boundary group & Reinstall DP & Re-added the new BG. Ccmclient got installed in servers & client with no error.
Regards,
Biswajit
i have the same issue but it's a nightmare to debug client to server communications : is there a guide somewhere to find out how to configure server and IIS to allow clients to communicate with sccm server `?
davidluong
