SOLVED CAS Site Recovery Issue
Vavamoose
Hi Guys!
I am administering a CAS recovery after a HA SQL cluster failure. The Cluster was dismantled, rebuilt and synced by an DB Admin, but obviously, this broke SCCM. The CAS would not connect pointing to a site recovery to reconnect the CAS to the new HA cluster Listener.
Towards the end, I got the following error on the wizard:
"Setup has encountered fatal errors while installing SMS services. Click the View Log button for more info"
The 'ConfigMgrSetup.log' has the below errors:
*** *** Unknown SQL Error!
CSiteControlSetup::Create_BackupSQLCert : Failed to get SSB certificate thumbprint.
CSiteControlSetup::SetupCertificateForSSB : Failed to create/backup SQL SSB certificate.
ERROR: Failed to set up SQL Server certificate for service broker on replica node "Contoso-SQL02" .
"Contoso-SQL02" is the secondary node of the HA SQL cluster.
SPN configs have not changed on the Domain
permissions are still same since this issue - rightly configured.
Firewalls are configured OK with appropriate ports.
All activities on the SCCM participating servers are carried out with a single service account.
I will appreciate any recommendations. I suspect DB recovery actions on this SQL02 node were not done with the service account but with a personal Domain Admin account, breaking SQL certs permissions.
I am looking for a way out of this. A little dig around the net points to a DB and Config Manager rebuild, but we are not considering this option yet.
Thanks in advance for all feedback.
I was able to make some headway today on this. below are not workstream notes. Hope this helps anyone who finds themselves where I am today, I am very poor with SQL hence my gibberish may not make sense to seasoned DB Admins, but be assured the query commands are correct:
  • CAS treats restored Cluster nodes as new DB Servers
  • This causes failure to start console on CAS due to DB connectivity issues (cert based) and causes sites to fail replication downstream.
  • Steps to restore sites
From MSSMS, connect to both DB nodes of the cluster separately and run the following querry...
selectname,collation_name,user_access_desc,is_read_only,state_desc,is_trustworthy_on,is_broker_enabled,is_honor_broker_priority_on fromsys.databases
This will list the db instances and their SSB status
  • Confirm that for the SCCM_CAS instance on each node, that Broker, trustworthy and Honor_broker_Priority has value of 1
  • If any is at 0, use below queries to enable
ALTERDATABASECM_PS1 SETENABLE_BROKER
ALTERDATABASECM_PS1 SETTRUSTWORTHY ONALTERDATABASECM_PS1 SETHONOR_BROKER_PRIORITY ON
  • From the E:\Microsoft Configuration Manager\cd.latest\SMSSETUP\BIN\X64, run setup.exe as Admin and select site reset
  • Veirfy replication status on SCCm console once you can connect
  • Be PATIENT as components re-initialize at CAS. This took almost 2 hours
  • Monitor logs - compmon.log, replmgr.log, rcmctrl.log
  • Verify replication and link health once components have iniitialized from the compmon.log
    • Run Query on the SCCM_SiteDatabase and resolve replication issues as normal
SPDiagDRS
From <https://learn.microsoft.com/en-us/t...ubleshoot-database-replication-service-issues>
  • Run link analysis for each site from CAS and also from site to CAS.
TobiasKMdS
