SOLVED Best Partitioning Scheme for stand alone MS-SQL (stabitily & performance)
sip03ds
In my humble opinion, and based on the fact you have numerous hard disks/disk arrays for partitioning, the best partitioning scheme for MS-SQL is the following:
  1. One partition for OS (C)
  2. One partition for the SYS_DB (D)
  3. One partition for the DB files (E)
  4. One partition for the DB_LOG files (F)
  5. One partition for the TEMP_DB files (G)
  6. One partition for the TEMP_LOG_DB files (H)
In this manner you can separate database from log files that will allow you to perform point in time recovery in case DB crashes.
Moreover, separate disks allow optimized I/O thus increase performance.
What is your opinion on the case?
robertosangalli
