- 1
- 0
- 1
I wanted to uninstall the Windows 10 patch using WSUS.
I checked that the patch is allowed to remove.
At least I tried to manually uninstall the patch from Windows 10 PC without issue.
When I approved a patch in WSUS for removal, there is no error on WSUS.
I tried to manual "check update" on Windows 10 PC in order to get the "removal task" from WSUS.
Unfortunately, nothing uninstalled even restarted the server.
I leave the PC alone for 1 day and there is still no luck.
I tried different solution as below already:
1. Use Troubleshooting function in Control Panel, there is no error found
2. Tried rename the SoftwareDistribution Folder and stop/start bits, wauaserv and crypsvc service
I checked the windows update log, there are some failed tasks:
6700 6556 DownloadManager *FAILED* [80246007] Could not find a locked revision for the child of the update 59078FAB-2346-43BE-A97C-C8CEBE8B43F3.200
304 16532 ComApi *FAILED* [80246007] ISusInternal:: IsCommitRequired
7304 2008 ComApi Download call complete (succeeded = 0, succeeded with errors = 0, failed = 1, cancelled = 0, unaccounted = 0)
7304 2008 ComApi ClientId = MoUpdateOrchestrator: Exit code = 0x00000000; Call error code = 0x80240022
6700 17300 Agent WU client calls back to download call {BCD895AD-F52A-47E4-9ABD-BBF9D2A60BD0} with code Call complete and error 0x80240017
7304 5824 ComApi Download call complete (succeeded = 0, succeeded with errors = 0, failed = 1, cancelled = 0, unaccounted = 0)
Anyone have a idea to troubleshoot the issue ?
Thank you very much.
