SCCM | Intune | Windows 11 Forums
SOLVED Turn off Auto-Startup for an App using SCCM
iBrokeMySCCM
Is there a way to prevent an app from starting up automatically using SCCM? There is an app that is set to auto-start and we need to disable it on all machines. It's a machine-wide startup for all users; not a profile startup option. If I disable it in the local admin account it disables it in all profiles.
Have you considered using scripts to achieve this?. For ex. you can add the line in your script and replace the "AppName" with the actual name of the application you want to disable at startup.
Code:
reg delete "HKCU\Software\Microsoft\Windows\CurrentVersion\Run" /v "AppName" /f
Code:
Code:
I will be pushing this out later in the week. I'll let you know if it's successful. Thanks for the help!
