gangaskan
- Solutions
- 3
i was able to migrate the DB, used a new instance, and used dynamic ports by mistake.
i was doing a pre req check and noticed that my server wasnt using static ports (1433) so i changed it and restarted the instance.
when i try to set systemcneter to use the right db i get this error
ConfigMgrSetupWizard Error: 1 : Exception message: [The target principal name is incorrect. Cannot generate SSPI context.], Exception details: [System.Data.SqlClient.SqlException (0x80131904): The target principal name is incorrect. Cannot generate SSPI context.
is this the right way to do that? or is it better to change the port in the registery?
