PENDING pxe-e16 no offer received
rankinf
Hello
We upgraded to SCCM 2107 5.00.9068.1008. After the upgrade our PXE is no longer working. We get an error showing:
Start PXE over IPv4
Station IP Address is (our internal ip range)
PXE-E16: No valid offer received
We took a look at the SMSPXE.log file and it has not updated since March of 2020. So, I am confused where to go next. Any assistance would be appreciated.
  • SMSPXE.log
AhmedLS
Active Member
41
if the smspxe.log is not updated that means it is created somewhere else. search for it on the pxe enabled distribution point. on the other hand try booting the laptop or desktop with another network card, like a usb network card or a docking station.
OP
R
rankinf
The distribution point is the same server. There is no other network card and using a docking station wouldnt fix the problem as we have to image 50 machines.
OP
R
rankinf
Made some progress. Found the wdsmgfw.efi in the \boot\x64 folder was missing. Copied a local version of it to the directory and now the pxe continues but fails stating that there is a problem now with the .wim file. In the updated log we see that
  • Like
Reactions: AhmedLS
V3TR4x
I had the same problem and my problem was the certificate
I updated every certificate from Sha1 to SHA256
I am not sure if this helps you
OP
R
rankinf
So we finally resolved the issue. We ended up doing the following:
1. Remove the PXE role
2. Remove the Multicast role.
3. Remove the WDS role(If installed manually).
4. Rebooted the machine.
5. DO NOT INSTALL WDS.
6. Renamed the RemoteInstall folder.
7. Reinstalled WDS (this will also re-create the Remoteinstall folder)
8. Enable the SCCM Multicast role and the SCCM PXE role.
9. Re-enabled the unknown machine option
After doing all that, PXE and the image began working again. What we are surmising is that the .wim files got corrupted somehow in the last patch to 2107 and PXE was broken somehow also in the upgrade.
adampershing
