SOLVED find certificate in clients using SCCM
takoroni
hi
i am new here.
is there a way find is a specific certificate is install at the client side ?
is there any rdl file for the sccm report server ?
can i see the ceridficate in the resource explorer ?
Roni
There are no built in inventory task for Certs and therefore no reports for this either.
You can use Configuration Item and Configuration Baseline to check for that specific certificate. Link
I once deployed wrong Certificate to Clients and use CI and CB to detect and remove the cert with Powershell.
