SOLVED Distribution Point Configuration Status stuck in "in progress"
awachens
Hi all!
I try to distribute content to specific DP and this still in progres with 726 packages.
Two days away this DP has been distributed the content correctly.
I check it distmgr.log and have no errors.
But i cant see some registry in pkgxmgr.log ... I dont know why.
This MP distribute content to anothers DP's correctly. I only have problems with this one. Space on disk its 95% free.
How can i continue with troubleshoot ?
Thx to all !!
Was solved!!
The problem is on secondary Site. We have a lot package in queue because few distributions point was down.
I mark these DP's in maintinance mode and the problem was solved. Secondary site start to send the content to this DP.
Thx to all !!!
OP
A
awachens
Ok!
I think is too slow.. We have one server in North Caroline and another one in Canada...
A part of this .. How can i check if DP is downloading content? Or Secundary is sending content?
UPDATE:
I have a lot packages here:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\SMS\COMPONENTS\SMS_DISTRIBUTION_MANAGER\Retry History
Regards and thx a lot!!
Forum Owner
Staff member
3,944
460
183
If the two DPs are far away and if there is a slow speed link, you can either wait until the content gets transferred or set up a Pull DP in case you have another DP closer.
OP
A
awachens
Was solved!!
Thx to all !!!
Datatekniker
