SOLVED CMPivot not returning any results, SQL error in SMSProv.log...
BobojoBaxter
We had an issue with another thing post console update, where we couldn't modify or even look at our cloud attach. We ran a sql command to update the user table I believe...
Now we have the issue where cmpivot has no results and the error in the smsprov.log is as follows:
SQL:
*~*~[42000][229][Microsoft][ODBC Driver 18 for SQL Server][SQL Server]The SELECT permission was denied on the object 'CMPivotResult', database 'CM_MEM', schema 'dbo'.     ThreadID : 18576 , DbError: 229 , Sev: 14~*~*
*** [HY010][0][Microsoft][ODBC Driver Manager] Function sequence error
*~*~[HY010][0][Microsoft][ODBC Driver Manager] Function sequence error   [42000][229][Microsoft][ODBC Driver 18 for SQL Server][SQL Server]The SELECT permission was denied on the object 'CMPivotResult', database 'CM_MEM', schema 'dbo'.
The user that ran the command is an sccm admin. I do still see the smsdbuser_readonly and it has execute permissions on dbo, so not sure it is that...
If I check the database it looks like the pivot did actually run, I can see the results in sql.
TasnimHasan
