NEW Autopilot OOBE Sign-In Fails for Federated Secondary Domain — “isn’t in our system”
kaplish
Hello everyone,
We’ve run into an issue during Windows Autopilot user-driven provisioning with a secondary domain that’s federated to JumpCloud.
  • Primary domain: stmarksschool.org (verified, managed — works fine)
  • Secondary domain: stmarkstech.org (verified, federated to JumpCloud)
  • UPN tested: [email protected]
  • The secondary domain has the correct CNAME DNS records for enterpriseenrollment and enterpriseregistration.
  • Federation with JumpCloud is configured and working correctly — signing into https://portal.office.com with the UPN redirects to JumpCloud and allows successful access to M365 apps.
  • The test user has proper Intune (A5) licensing and exists in Entra ID.
When I attempt to enroll a Windows 11 device via Autopilot (OOBE) using this federated secondary domain, I get the following error immediately after entering the UPN:
“stmarkstech.org isn't in our system. Make sure you typed it correctly.”
However:
  • If I use a UPN from the primary domain (stmarksschool.org) or the default onmicrosoft.com domain, Autopilot enrollment works perfectly.
  • The same [email protected] account signs into Office.com with no issues, proving federation is set up correctly.
I’ve verified:
  • The domain is fully verified and federated in Entra.
  • Intune configuration and Autopilot profile assignment are correct.
  • DNS records are in place.
  • The issue happens on multiple freshly imaged Windows 11 devices, both pre-provisioned and user-driven.
Has anyone encountered this behavior before with federated secondary domains during Autopilot enrollment?
Is there anything additional that must be configured on Microsoft’s side to make a federated secondary domain usable during the OOBE sign-in step?
Any guidance or insight would be greatly appreciated.
Onmartin
