SOLVED Automatic Deployment Rule for W11 25H2
moulouy
I am busy to configure the ADR for windows 11 in SCCM.
My windows 11 is the version 24h2, but when i begin to enable the product i see only "Windows 11" or "Windows 11 client , version 24H2 servicing drivers" NOT "Windows 11 version 24H2 and later" like Windows 10,
If i choose Only Windows 11, i will have more unnecessary download? is there a possibility to check windows 11 version 24h2 and later?
For the update classification is it enough to check : Security Updates ,Critical Updates, Updates?
My Sccm Version is 2409
All you have to do is select Windows 11 product under SUP. The other ones are optional. For update classifications, yes security updates, critical updates and updates are good. You may select upgrades for performing in-place upgrades. For more details, refer this post - https://www.prajwaldesai.com/create-automatic-deployment-rule-in-sccm/
justkellen
