SOLVED Urgent help Update hotfix SCCM problem
  • Thread starter Thread starter namnv
  • Views Views 6K
namnv
Dear All,
I have an ADR to automatic update hotfix for window Server 2012.
But problem is some server can receive the update when it run, but another server is cannot receive update.
I attact the log file and image in error server
I troubleshooting but not sucessful,
Please help me.
Code:
2018-09-05    14:52:29:170      80    a44    Misc    WARNING: Network Cost is assumed to be not supported as something failed with trying to get handles to wcmapi.dll
2018-09-05    14:52:29:201      80    a44    Misc    WARNING:     IsSessionRemote: WinStationQueryInformationW(WTSIsRemoteSession) failed for session 2, GetLastError=2250
2018-09-05    14:52:29:202      80    a44    Misc    WARNING:     IsSessionRemote: WinStationQueryInformationW(WTSIsRemoteSession) failed for session 3, GetLastError=2250
2018-09-05    14:52:29:206      80    a44    AU    WARNING: Failed to get Wu Exemption info from NLM, assuming not exempt, error = 0x80240037
A similar issue is covered here. Can you try the belows steps
1. Click on Start, and then click Run.
2. Type cmd in the Open box to get a DOS prompt.
3. Type "net stop wuauserv" without the quotes at the command prompt, and press
Enter.
4. Delete (or put in recycle bin) the contents of
C:\WINDOWS\SoftwareDistribution (but not the SoftwareDistribution folder)5. Type net start wuauserv at the command prompt, and press Enter.
6. Now try Windows Update again.
Try this. go to C:\WINDOWS\System32\GroupPolicy\Machine and check the last modified date on the registry.pol file. If it is old, rename the file to registry.OLD then go into configuration manager applet in control panel and run machine policy retrieval and software update eval cycle. That will start the new policy
joita
