NEW Show Basic Installation Progress to End Users through Configuration Manager Console
Murugesan
Hello Team
Is it possible to show the installation progress to end users via SCCM Console without using a PowerShell script?
End users should receive notifications of software download and installation progress, even if the Software Center is closed.
I tried below steps but that not worked, only I got the Blank PowerShell Window opened during installation.
  • Installation behavior: Install for system
  • Logon requirement: Only when a user is logged on
  • Installation program visibility: Normal
  • Allow users to view and interact with the program installation: this should be checked
Anyone could help on this__
Thank You!!
Hello Team
Thank You!!
This will depend on your program to display output. if it doesn't display anything then the end users will see nothing.
You mean it's based on the PowerShell scripts we wrote to create an application?
Our requirement is that we do not touch anything in the script, however we are investigating whether this is achievable through the SCCM console. Our end users expect to be able to view the download and installation progress without having to open the Software Center. Do we have anything for this?
I'm not sure what you are expecting, if your app does not show anything, why would you expect ConfigMgr to create and display install status?
