SOLVED SCCM PXE not working
RoelofStrydom
Active Member
Good day fellow SCCM'ers,
I have an issue with PXE on a certain site, not certain MP, just a site. let me explain :
We have a few MP's on our environment , they all use the same Boot Image but this particular site is not working. Local site informed me that the PXE is not working it stays on "Starting PXE on IPv4".
I did the following :
1. Reboot DP , tested and still not working.
2. Redistribute the Boot image - Still not working
3. Removed the PXE role , rebooted DP and re-added PXE role, still not working.
4. Removed PXE role again, rebooted DP, manually removed WDS role, rebooted DP , Re-added PXE Role, rebooted DP when done , tested and PXE was working.
The above was done last week Friday , site advised me again yesterday that PXE is not working again.
I did the same as in step 4 and still PXE was not working.
I can see the DHCP server is leasing the IP to the client, but the client is no progressing pas the "Starting PXE on IPv4"
I decided to create a new DP with the PXE role yesterday and waiting over night for the sync to complete. I asked the network team to change the IP Helper to the new IP . Tested and the results are the same as the old DP, PXE getting stuck at "Starting PXE on IPv4".
Checked the SMSPXE log and the last entry is :
Operation: BootReply (2) Addr type: 1 Addr Len: 6 Hop Count: 0 ID: 9C199E9B
Sec Since Boot: 3 Client IP: 010.031.088.066 Your IP: 000.000.000.000 Server IP: 010.031.004.130 Relay Agent IP: 000.000.000.000
Addr: 00:15:5d:6e:81:23:
BootFile: smsboot\x64\wdsmgfw.efi
Magic Cookie: 63538263
Options:
Type=53 Msg Type: 5=Ask
Type=54 Svr id: 010.031.004.130
Type=97 UUID: 00e5d636d35a4e5a4eb412185d8c7c8488
Type=60 ClassId: PXEClient
Type=250 02010105040000002103020014040200ba062c436f6e66696775726174696f6e204d616e61676572206973206c6f6f6b696e6720666f7220706f6c6963792e0b0101
Type=252 5c534d5354656d705c323032362e30392e32322e31322e30392e30332e30362e7b46364530424246442d443743342d343438332d394434422d3834353541453643323037447d2e626f6f742e62636400
If we change the IP helper to point to a working DP on another site, the PXE is working but it will take forever to finish 1 PXE machine.
I have no idea what else to do/check, any ideas?
Regards
Just an update, we added the DHCP option and 67 to the Scope Option and PXE started to work again. This is strange as we are using IP helpers and never had the DHCP Scope options set. Seems to be an issue with the DHCP/PXE network path or something.
In the remote site where you have PXE issue, does that site includes multiple VLANs or its a single VLAN configured?
Hi, the site has multiple VLANS same as our other sites, hence the IP helper config on the network switches. This use to work with no issues and it just decided to stop.
If PXE functions correctly with DHCP options but not with IP Helpers, this is likely an issue your network team should investigate.
