SCCM Education License
timmyrichy123
Hello together,
about 4 Months ago I started the my experience with SCCM.
Now the License will expire in several Weeks.
Does anybody know, if it exist a Education License, which not expire after 180 Days ?
1300 € are too much for a private Person, who will learn how SCCM works with non commercial use.
OP
timmyrichy123
timmyrichy123
Use the CM Technical preview, it is free with 10 client usages.
Is it possible to change from my current Installation to the technical peview ?
If its Not possible:
Are any known Problem when i add a new SCCM server to my existing Domain?
Could I use the same Hostname like the old Server ?
Garth
Staff member
1,469
123
63
No it is not possible
You can have as many CM environments as you like.
If you like but I would do it. Same thing as site code. NEVER reuse them.
j_dahl9
Staff member
8
@timmyrichy123
If you want to set up a lab environment, you will get 180 days or so to use it, but I recommend downloading the Windows and Office 365 deployment lab kit.
I have used this quite a bit, and it builds out everything for you if you have the hardware to run it. I can run this on my local PC, but it does require a good deal of CPU and RAM, but it has worked great for me.
Let me know if you have any questions!
OP
timmyrichy123
timmyrichy123
@timmyrichy123
Oh that's interesting.
i will try it, after I read about it.
M Werfalli
