SOLVED SCCM client installation issue on computers
Hello I have just built SCCM 2016.
I have hyper v manager running a Ad domain a Server for my sccm and 1 windows 10 client. all are communicating. i can ping and nslookup all workings find.
I have run discovery and enabled fallback.
I just tried to configure the push client to my windows 10 pc Client1 and its not registering in the devices and collections.
I looked at the c:\windows and there is no ccmsetup folder.
please can you advise what i should check for?
Hi I have just made a amendment after much searching I noticed that there wasn't a c:\windows\cmsetup folder. So i ran cmsetup from the tools and the folder was created and all the necessary files were added. I also added the computer ou under the discovery options, after dosing so the client pc was listed. I have now right clicked the client pc and choose install client. The isntall said it was successfull but the client hasnt installed
Wow I have surprised my self :) the problem I has was the accounts push section where not part of the clients local Admin$ after creating and adding this i was able to deploy the config manager client.
Yes client push install account must be configured before you deploy the client agents to all machines. Glad to hear you resolved the issue.
