SOLVED SCCM 2403 to 2409 update stuck at installation checking prerequisites
  • Thread starter Thread starter inshaf
  • Views Views 9K
inshaf
1. I run prerequisites before installation .
Got Below Warning -
[Completed with warning]:The site server configured with HTTPS/Enhanced HTTP, does not require network access account. Please verify the minimum appropriate permission of this account(s) and remove the account(s) which has higher privileges. We recommend you remove the configured network access account(s) which are not leveraged.For more information about your network access account required permissions, see https://go.microsoft.com/fwlink/?linkid=2210348.
Post to this Warning i noticed it stuck in installation as shown in attached image .. when i check cmupdate log i see this as last log at that time "
Update package will not install as it is marked for prereq check only. CONFIGURATION_MANAGER_UPDATE 1/7/2025 4:50:52 PM 4352 (0x1100) "
I need help on how to reinitiate the update to complete as the option for retry and ignore prerequisites were all grey out i cant proceed further .
I try to run cmupdate reset tool also here is the error message - " [Error] 0x80131500 - Package is in post-replication state. CMUpdateReset.exe cannot reset the update. "
Any luck with this issues please? I have the same issue.
Yes, i could solve the problem. It is a bug in the SQL Query you can find in the configmgrprereq.log!
INFO: Query Select * from [dbo].[vSMS_SC_AccountUsage] ~WHERE UsageName IN ('SMS Multicast Service Point','Software Distribution') and UserName NOT IN ('NULL') ~ returned one or more rows.
And yes, it returned a row - but with a empty userName! We are not using NAA.
If you disable Multicast at your distribution points - this query gives no more outputs and the precheck is now successfully without warning.
Got Below Warning -
Blackcee
