SOLVED OS Upgrade, Execution engine result code: Reboot (2) error
ismaildedeler
Hello everybody,
I have Windows 7 client and I want to upgrade to Windows 10. I created Task Sequence for in-place upgrade. Everything good. Operating system updated. But after restart task sequence does not continue. SMSTS Folder not delete. Does anyone have an idea?
Best regards.
Windows Upgrade Setup progress: 83% OSDUpgradeWindows 10/28/2019 07:47:25 5988 (0x1764)
Windows Upgrade Setup progress: 94% OSDUpgradeWindows 10/28/2019 07:47:35 5988 (0x1764)
Windows Upgrade Setup progress: 96% OSDUpgradeWindows 10/28/2019 07:47:45 5988 (0x1764)
Waiting for Windows Upgrade Setup process to return ... OSDUpgradeWindows 10/28/2019 07:47:56 5988 (0x1764)
Process completed with exit code 0 OSDUpgradeWindows 10/28/2019 07:48:09 4764 (0x129C)
ExecuteWithTimeout returned Windows Setup process hexadecimal exit code 0x00000000 (decimal 0) OSDUpgradeWindows 10/28/2019 07:48:09 4764 (0x129C)
Wait for event returned 0 OSDUpgradeWindows 10/28/2019 07:48:09 5988 (0x1764)
Windows Setup completed with exit code hexadecimal 0x00000000 (decimal 0) OSDUpgradeWindows 10/28/2019 07:48:09 5988 (0x1764)
Saving exit code of Windows upgrade - hexadecimal 0x00000000 (decimal 0) - to Task sequence environment variable '_SMSTSOSUpgradeActionReturnCode', as decimal string OSDUpgradeWindows 10/28/2019 07:48:09 5988 (0x1764)
Windows Setup completed successfully! OSDUpgradeWindows 10/28/2019 07:48:09 5988 (0x1764)
Exiting with code 0x00000000 OSDUpgradeWindows 10/28/2019 07:48:09 5988 (0x1764)
Process completed with exit code 0 TSManager 10/28/2019 07:48:09 4148 (0x1034)
!--------------------------------------------------------------------------------------------! TSManager 10/28/2019 07:48:09 4148 (0x1034)
Successfully completed the action (Upgrade Operating System _ United Kingdom) with the exit win32 code 0 TSManager 10/28/2019 07:48:09 4148 (0x1034)
Not in SSL TSManager 10/28/2019 07:48:09 4148 (0x1034)
Set a global environment variable _SMSTSLastActionRetCode=0 TSManager 10/28/2019 07:48:09 4148 (0x1034)
Set a global environment variable _SMSTSLastActionName=Upgrade Operating System _ United Kingdom TSManager 10/28/2019 07:48:09 4148 (0x1034)
Set a global environment variable _SMSTSLastActionSucceeded=true TSManager 10/28/2019 07:48:09 4148 (0x1034)
Clear local default environment TSManager 10/28/2019 07:48:09 4148 (0x1034)
The action (Upgrade Operating System _ United Kingdom) requested a retry TSManager 10/28/2019 07:48:09 4148 (0x1034)
Created volatile registry entry for pending reboot initiated by this task sequence TSManager 10/28/2019 07:48:09 4148 (0x1034)
Executing command line: "bcdedit.exe" with options (0, 0) TSManager 10/28/2019 07:48:09 4148 (0x1034)
Process completed with exit code 0 TSManager 10/28/2019 07:48:10 4148 (0x1034)
TSUEFIDrive: TSManager 10/28/2019 07:48:10 4148 (0x1034)
Updated security on object C:\_SMSTSVolumeID.7159644d-f741-45d5-ab29-0ad8aa4771ca. TSManager 10/28/2019 07:48:10 4148 (0x1034)
Updated security on object E:\_SMSTSVolumeID.7159644d-f741-45d5-ab29-0ad8aa4771ca. TSManager 10/28/2019 07:48:10 4148 (0x1034)
Updated security on object C:\_SMSTaskSequence. TSManager 10/28/2019 07:48:10 4148 (0x1034)
Set a global environment variable _SMSTSNextInstructionPointer=16 TSManager 10/28/2019 07:48:10 4148 (0x1034)
Set a TS execution environment variable _SMSTSNextInstructionPointer=16 TSManager 10/28/2019 07:48:10 4148 (0x1034)
Set a global environment variable _SMSTSInstructionStackString=6 14 TSManager 10/28/2019 07:48:10 4148 (0x1034)
Set a TS execution environment variable _SMSTSInstructionStackString=6 14 TSManager 10/28/2019 07:48:10 4148 (0x1034)
Save the current environment block TSManager 10/28/2019 07:48:10 4148 (0x1034)
Expand a string: %_SMSTSMDataPath%\Logs TSManager 10/28/2019 07:48:10 4148 (0x1034)
_SMSTSReturnToGINA variable set to: TSManager 10/28/2019 07:48:15 4148 (0x1034)
SMSTSUninstallCCMClient variable set to false TSManager 10/28/2019 07:48:15 4148 (0x1034)
_SMSTSCaptureMedia variable set to false TSManager 10/28/2019 07:48:15 4148 (0x1034)
The action (Upgrade Operating System _ United Kingdom) initiated a reboot request TSManager 10/28/2019 07:48:15 4148 (0x1034)
Not in SSL TSManager 10/28/2019 07:48:15 4148 (0x1034)
**************************************************************************** TSManager 10/28/2019 07:48:16 4148 (0x1034)
Execution engine result code: Reboot (2) TSManager 10/28/2019 07:48:16 4148 (0x1034)
Task Sequence Manager ServiceMain finished execution. TSManager 10/28/2019 07:48:16 4148 (0x1034)
Task Sequence Manager execution terminated as system shutdown is in progress. Code 0x00000000 TSManager 10/28/2019 07:48:16 4148 (0x1034)
RegQueryValueExW is unsuccessful for Software\Microsoft\SMS\Task Sequence, SMSTSEndProgram TSManager 10/28/2019 07:48:16 4148 (0x1034)
GetTsRegValue() is unsuccessful. 0x80070002. TSManager 10/28/2019 07:48:16 4148 (0x1034)
End program: TSManager 10/28/2019 07:48:16 4148 (0x1034)
Stopping Task Sequence Manager service TSManager 10/28/2019 07:48:16 4148 (0x1034)
RegQueryValueExW is unsuccessful for Software\Microsoft\SMS\Task Sequence, SMSTSEndProgram TSManager 10/28/2019 07:48:16 1612 (0x064C)
GetTsRegValue() is unsuccessful. 0x80070002. TSManager 10/28/2019 07:48:16 1612 (0x064C)
End program: TSManager 10/28/2019 07:48:16 1612 (0x064C)
Hello Sam,
The task sequence is as follows.
Virtual disk= sc config vds start=demand
I have 2 language so I use 2 steps on task sequence.
Network Location Awareness Service= net start nlasvc
Under Upgrade Operating System -> Why do I see two steps with Upgrade Operating System and are they different ?.
I have an operating system in two different languages. TR and EN. If operating system language= 1033, Install English ISO. If operating system language = 1055, Install Turkish ISO.
I changed the task sequence by default but still the problem is the same. SMSTS folder is not deleted after restart. Operating system upgrade succesfull.
mjmagyar
