Sheikh Jawa
The issue with DP: Driver packages keep failing to Distribute to DP, Due to which the build fails. Getting this message.
Package Transfer Manager failed to update the package "FT000392", Version 4 on distribution point Srv-xyz . Review PkgXferMgr.log for more information about this failure.
Possible cause: Site server does not have sufficient rights to the source directory.
Solution: Verify that the site server computer account has at least Read access to the directory you specify as the source directory.
Possible cause: There is not enough disk space available on the distribution point.
Solution: Verify that there is enough free disk space available on the distribution point.
_______________________________________________________________________________________________________________________
To clarify, correct permissions are in place and there is enough space on the distribution point. Additionally, there are instances where the distribution is successful.
