Tahsin Yusuf Demir
On September 30, we had to move our SCCM server's database to another server. During this process, we get errors on some of our distribution points. However, after the operation, I send packages to these distribution points and I don't have any problems and when I check, these DPs are accessible. When I examine the Distmgr.log, I don't see any errors. I checked the network access and ports in various ways, there is no drop. These DPs are connected to another DP as pull dp. The DPs that gave the error sent a status message on the same day and at the same time. I need to reset this somehow and turn all DPs green.
There is a sql command that I use to delete warnings on DPs, and it works very well for me. I don't know if I can find a similar command that I can delete with errors.
I am sharing the sql query that deletes warnings in case it is needed.
delete from dbo.DistributionStatus where LastStatusMsgID = '2388'
delete from dbo.DistributionStatus where InsStr2 = '3010'
exec spRebuildContentDistribution 1
