CryptVerifySignature failed, 80090006
  • Thread starter Thread starter Mds
  • Replies Replies 1
Mds
Hello everyone,
I had an active site server and a passive site server. The following roles were installed on the active site server: Management Point, Distribution Point, SUP. These roles must also be installed on the passive site server as soon as it is switched to active. During the migration, I removed the Distriibution Point role from the active Site Server to make ManageContentLibrary above the button in SCCM. Status is 100% migrated the ManageContentLibrary on the drive D$\SCCMContentLibrary" of the new server.
I then switched the passive site server to active. All logs are clean. Tested the PXE refueling, worked fine.
I then wanted to delete the old active site server from SCCM, I deleted Distribution Point and then removed Management Point. Then came a call that the PXE refueling no longer works on any client. The client gets an IP address from the DHCP but on the display of the client you only see “PXE over IPV4” remains until it switches to IPV6 then nothing happens. In the SMSPXE. log I see the following: 1) CryptVerifySignature failed, 80090006
2) untrusted certificate: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX, , YYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY
3)Unsuccessful in getting MP key information. 80090006.
4)PXE::MP_InitializeTransport failed; 0x80090006
5)PXE Provider failed to initialize MP connection.
Element not found. (Error: 80070490; Source: Windows)
I have removed the DP role on the new activ Site Server and also removed the Management Point role. Also removed WDS from the Server Manager and reinstalled it. Restarted the site server X times. PXE deactivated and reactivated. Redistributed the boot image. Unfortunately, none of this helped. I ask you for a very detailed steps on how I can fix the problem.
Thank you very much
Did you check with your network team on this issue?. If you're using IP helpers, you need to tell where should the client looks for the PXE server.
angrygoat
