NEW Citrix VDA Install using Task Sequence - Autologon
techlambo
We have a situation with this install in our environment. Since Citrix VDA cleanup and install require mandatory reboots in between the installation, we decided to deploy it through SCCM task sequence. I was able to get information on different forums as it appears others have done it this way as well.
What I really need help with is how to handle continue automatically after reboot piece. Do I have to add an autologon in the TS to make it work? Since it requires multiple reboots, we thought user intervention should not be required at every login to continue the TS.
Has anyone run into an issue like this before? If so, whats the best way to handle this?
